Quad Cab/Ext Cab frame swap?
Old Feb 10, 2007 | 02:25 AM
cdriedger's Avatar
cdriedger
Default Quad Cab/Ext Cab frame swap?
Anyone know if you can take a frame from an Ext. Cab short box and put a Quad cab short box on it?
C.
Old Feb 10, 2007 | 07:21 AM
BAnders's Avatar
BAnders
Default RE: Quad Cab/Ext Cab frame swap?
sounds like a good idea but you would probably be better off buying a quad cab
Old Feb 10, 2007 | 09:36 AM
lil's Avatar
lil
I had a club cab and now have a quad cab, the dealer told me (and of course the info maybe incorrect) they have the same frame but the club cab's cab is 8 inches shorter and the bed is 8 inches longer than the cab and bed of the quad cab.....they have the same frame and wheel base is the same 131.1 inches....you might need to mod some mounting hardware but it seems this swap would be possible
Old Feb 10, 2007 | 02:31 PM
horatio102's Avatar
horatio102
You'd have an 8" gap between your cab and bed, if you wanted the wheel wells and the tires to line up right. If that's what you're going for, then bully for ya.
