sponge brakes
Old Feb 13, 2007 | 09:05 PM
midnight.dakota1's Avatar
midnight.dakota1
Default sponge brakes
so i've had my 98 dakota for about 5-6 months now and i have already replaced the brake master cylinder on it once due to right b4 they sold it to me someone accidently put power steering fluid in the brake fluid and it made my brakes screw up huge, now its doing it again i've gotta also put a full bottle of brake fluid into it every single day its really starting to **** me off there has to be a leak in the line somewhere n e suggestions on what i am capable about doing in this scenerio???
Old Feb 13, 2007 | 09:26 PM
jonnymagnum's Avatar
jonnymagnum
Default RE: sponge brakes
that sounds like a big leak, can you see it dripping anywhere?
I would get some one to step on the brakes while you get underneath looking for leaks.
Old Feb 13, 2007 | 09:53 PM
Cheeto23's Avatar
Cheeto23
Is there fluid collecting in the brake servo (vacuum booster)? If the rear of the master cylinder is leaking (into the servo), engine vacuum could be drawing it into the servo.
Old Feb 13, 2007 | 11:54 PM
midnight.dakota1
i'm gonna try the get someone to step on the brakes idea i got no clue what in the hell is a stervo is
Old Feb 14, 2007 | 12:00 AM
01dodgedriver's Avatar
01dodgedriver
probably some leaky wheel cylinders. the fluid is probibly soaking in to the brake dust. i would pull the rear drums off and take a look at them.
Old Feb 14, 2007 | 03:10 PM
Chris's Avatar
Chris
Put the truck on jack stands. Take all of the wheels off. Go through each brakecaliper (and/or drum)and have someone press the brakes while you inspect. If you can't find it, check all hard lines running from the fluid resivoir. Also, check under your driverside floormat and under the driverside dash, near the firewall. If you have fluid sitting around in there, it is your brake master cylinder. If you are losing that much fluid daily, it has to be going somewhere. Look for the puddling of the lost fluid, and that will tell you where your leak is coming from. I don't care how much brake dust you have, it is not going to hide that much fluid. However, to be safe, clean your wheels VERY WELL if you can't find the leak after doing everything stated before. When you put the clean wheels back on, drive it around for a day or two and look again. You should be able to see if it is leaking at the brake calipers.
This should be a simple fix. If you are losing as much fluid as you say you are, you should be able to find where it is going if you look hard enough.
Old Feb 14, 2007 | 11:04 PM
Cheeto23's Avatar
Cheeto23
ORIGINAL: virused
...check under your driverside floormat and under the driverside dash, near the firewall. If you have fluid sitting around in there, it is your brake master cylinder.
It cannot end up under the floormat. Because these vehicles have pqwer brakes, the fluid would end up inside the power brake booster (the servo). This is the thing your master cylinder is bolted to, the big vacuum reservoir against the firewall.
