remote start/keyless entry revisited
Old Feb 16, 2007 | 11:07 PM
mikec04's Avatar
mikec04
Default remote start/keyless entry revisited
Have made progress, but the Bulldog remote will work only if the parking lights are connected to the remote module. The wire to be tapped into is a black/yellow (+) located behind the fuse panel. I do not know if it's in the vacinity of the fuse panel, or at the panel itself. It looks like a roadmap of Detroit under there.
If someone has a schematic of the body wiring, would you like to share it off line? Let me know and I'll supply e-mail address
thanks
[sm=helpout.gif]
[sm=groupwave.gif]
Old Feb 16, 2007 | 11:47 PM
imnothot02's Avatar
imnothot02
Default RE: remote start/key-less entry revisited
just go up to the switch it is much easier, yes the wire is down there but you will have a heck of a time A finding it B taping it any other help I'm me I'm well versed in this area
Old Feb 16, 2007 | 11:58 PM
mikec04's Avatar
mikec04
Was thinking of splicing into the headlight switch wire. All I gotta do is get it unplugged. I'll let you know how it turns out when it warms up a bit. Got cold enough just getting to this point. Gonna have to get a lot warmer to get the keyless wired.
[sm=goodidea.gif][sm=thanx.gif]
Old Feb 17, 2007 | 01:11 AM
imnothot02's Avatar
imnothot02
no problem keep me posted
one thing that i do is mount the "brain" first then cut off excess wire as you splice and tap wires, makes for a much cleaner install... oh and for wiring let me know what year it is...
