Lift for my dakota
Old Mar 5, 2007 | 10:17 PM
BeachCruiser's Avatar
BeachCruiser
Default Lift for my dakota
I've got a 97 3.9L 2wd std cab dakota that I'd like to lift. Just for looks, I won't be doing any off-roading. At most I'll driving on the beach so I don't need a heavy duty suspension. Can I combine this 3" body lift with this 2" front leveling / add-a-leaf kit for a total of 5" lift? Hope so... Also how big would I be able to go with my tires, can I fit 33's? I'll get BFG A/T, my rims are 15x8 and I'm not sure on the exact backspacing, but they stick out from the body a good 2 inches. Thanks
Old Mar 5, 2007 | 10:23 PM
imnothot02's Avatar
imnothot02
Default RE: Lift for my dakota
idk yabeter search...answer this every week on here[sm=groupwave.gif][sm=groupwave.gif]
Old Mar 5, 2007 | 10:52 PM
batman13's Avatar
batman13
looks to be OK but....
make sure the trip you take to break it in should end at an alignment shop.
you could fit 34-35" with that much lift
my 2x4 dak came stock with 31x10.5s and never rubbed once
Old Mar 5, 2007 | 11:09 PM
BeachCruiser
Yea, it needs an alignment anyway. What year is yours? There is no way mine could fit 31x10.5 stock, it has 235-75-r15's (about 29x9.25) and they almost rub. Whats up with that?
Old Mar 5, 2007 | 11:23 PM
batman13's Avatar
batman13
mines a 97
the big tires were apparently the only option this truck came with,
I don't even have A/C
Old Mar 5, 2007 | 11:36 PM
BeachCruiser
On that same truck in your sig? Your truck looks level, mine sits about 2 inches lower in the front. They'd fit in the back no problem. Did you install a leveling kit, or is my truck just ghetto?
Old Mar 5, 2007 | 11:39 PM
batman13's Avatar
batman13
Yours must just be ghetto
It's not level at all
my rear's about 2 inches higher 'cause I staggered my tires
Old Mar 5, 2007 | 11:43 PM
BeachCruiser
Just thought of this, would I need a longer driveshaft with a 5" body lift? I hope not
Old Mar 5, 2007 | 11:48 PM
batman13's Avatar
batman13
you might need to put shims to straighten it out
but I don't think you'll need to because half of your lift is a body lift
Old Mar 6, 2007 | 07:47 AM
offroadgolfer's Avatar
offroadgolfer
HA!! My 97 came with 31.5's AND a.c. from the factory!!
