fuse problem
Old Mar 7, 2007 | 06:05 PM
mrubeck's Avatar
mrubeck
Default fuse problem
Could anyone tell me where the power lock fuse is in the box? Doesn't seemed to be labeled in the cover. Also anyone else been having problems with the backup light fuse popping or could tell me where the problem could be. Thanks
Old Mar 7, 2007 | 06:54 PM
red9535's Avatar
red9535
Default RE: fuse problem
As far as the fuse goes, i'm not sure.. i dont feel like going out to look. But if its not labeled, its possible there isnt one.. they are operated by solenoids located in the doors, and there might just be a relay. I'd defintely take a closer look at your fuse box first, though. The one in the cab, and also the one under the hood.. i'm sure its there somewhere.
As far as the other fuse blowing.. do you have anything tapped into it? Probably a short somewhere. Check your powers and grounds and ****.
