seat belt buckle
Old Mar 8, 2007 | 01:22 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
Default seat belt buckle
On my truck the drivers side seat belt buckle is stiff to get the belt into, but when you go to release it it releases fine. The bukle is the part that stays on the right side of the drivers seat and it will only accept the locking piece if you push it in a certain way, any ideas/fixes for the problem, was going to try switching it for another belt end in the truck, maybe the one on the drivers side in the back (my truck is a club cab, no back doors, but back seats) would this work, does anybody know?? thanks in advance
Old Mar 8, 2007 | 05:42 PM
2000dakota4x4's Avatar
2000dakota4x4
Default RE: seat belt buckle
I don't see why that wouldn't work. Just do a quick check to make sure the back belt is the same length as the front one. I can't say for fact cause I have a regular cab. You may be able to stretch the front belt all the way to the back, the reverse, to see if this will fix your buckle binding problems.
Old Mar 9, 2007 | 01:13 AM
shrpshtr325
THE ULTI-MOD
i will try that but when i got the truck both of the front buckles did it until i lubricated them, then the passenger one stopped doing it and worked fine, but the drivers one kept acting up i was just hoping to get a definite answer on that before i took the entire front seat assembly out to get it off, and the entire back seat assembly apart to get at the buckle in the back, but i will try and measure, and test that theory and let you know was hoping for someone else who had the same problem, or knew how to get the front seat off without the whole bench coming up
