need help fast! electric fan problems
Old Mar 8, 2007 | 06:46 PM
Minion's Avatar
Minion
Default need help fast! electric fan problems
i installed an electric fan and now my radio doesnt work, and my car alarm goes off when i put my key in the ignition. when i start the car the alarm stops going off. radio doesnt even turn on. i did get the fan working though. please give me some help. i checked the fuse.
jake
Old Mar 8, 2007 | 07:05 PM
GeosRam's Avatar
GeosRam
Default RE: need help fast! electric fan problems
Oh wow, electrical gremlins... What triggers the switch on the fans to turn them on and off? Where are you getting power from?
Old Mar 8, 2007 | 07:13 PM
Minion's Avatar
Minion
i installed a manual switch. the fan is hooked up to b+ and the negetive fan side is ran to the switch and a wirecome out of the switch and goes to a good ground.
Old Mar 8, 2007 | 07:23 PM
Minion's Avatar
Minion
wtf...i moved my truck and now the alarm doesnt go oof but now my door locks dont work. the remote lock doesnt work either.[:@]
Old Mar 8, 2007 | 08:08 PM
Chris's Avatar
Chris
Take the wiring out and start from scratch. It sounds like you have a nightmare on your hands.
Old Mar 8, 2007 | 09:39 PM
2000dakota4x4's Avatar
2000dakota4x4
I agree with Chris, start over. This shouldn't matter but why do you run the ground to the switch and not the hot.
Old Mar 9, 2007 | 12:50 PM
Minion's Avatar
Minion
if the switch is on the hot side there will be a small spark every time you want to turn on the fan. but there is no spark on the negitive side. its is for the same reason that you disconnect the negitive side of the battery first then the positive side.
