popping sounds?
Old Mar 17, 2007 | 02:17 AM
dodgetruckpimp's Avatar
dodgetruckpimp
Default popping sounds?
Hi everyone, i've got a 1999 dodge dakota 5.2L 4x4
Myproblem is wheneverI step on the gas hard to accelerate my truck makes almost like a popping noise? but it only happens when my RPM' s reach 3K-4K, and as soon as my RPM's drop again it stops.would anybody be able to guess as to what the problem might be?
thanks
Old Mar 17, 2007 | 05:02 AM
imnothot02's Avatar
imnothot02
Default RE: popping sounds?
where is it coming from...? kinda hard to help im assuming the motor...?
Old Mar 17, 2007 | 05:28 PM
rtkota5point9's Avatar
rtkota5point9
Sounds like detonation (spark knock). Check your plenum gasket. Look down into the throttle body with a flashlight. If you see oil in the bottom of the manifold, you'll need to swap the gasket. A bad plenum gasket can cause a lot of spark knock.
