2 questions ??
Old Mar 25, 2007 | 05:33 PM
racin_40's Avatar
racin_40
Default 2 questions ??
Ok first ,
i was cleaning up my dakota and was wiping down the drivers sides jamb and noticed the factory sticker there
why would it say 215/75/R15's ?
i am running 32x11.50's now !!
secondly ,i was toldby ppl on here i need intake gaskets ,because of the valves rattleing like a preignition knock and using oil but not smoking .
do i only need the intake gaskets or is there any others i need to replace to take care of this ?
Old Mar 25, 2007 | 07:57 PM
imnothot02's Avatar
imnothot02
Default RE: 2 questions ??
what model is it...
Old Mar 25, 2007 | 08:40 PM
horatio102's Avatar
horatio102
215/75r15 is a 28" tire, which would be the OEM size for your truck, you got a 2wd?
As far as the intake plenum gasket - if you've got a 3.9/5.2/5.9 then yeah, if it's sucking a bunch of oil, pinging, but not really burning the oil, take your air hat off the throttle body, open the throttle, and look down into the intake manifold with a light. If you can see a puddle of oil then you need to remove your intake manifold and replace the plenum gasket. There are different products that'll cure the evil, OEM replacements seem to fail even though Dodge "fixed" the problem. It's a design flaw, but go to www.hughesengines.com and find their fix. If there's a light mist of oil that's considered normal, but if it's pooled up at all then you've got a leak.
I need to check mine too, two oil changes ago I was 2 quarts low on 3000 miles. Last time I was just a quart low, but that's still more than I like.
Old Mar 25, 2007 | 09:30 PM
racin_40's Avatar
racin_40
sorry i thought i clicked the add sig ,but anyway it is the following
99' extended cab 4x4 5 speed ,5.2 liter ,w/CAI and magnaflow 1 in 2 out cat back dauls
Old Mar 25, 2007 | 10:10 PM
imnothot02's Avatar
imnothot02
thats OE from the factory but 31-10.5-15 was a option...
Old Mar 26, 2007 | 12:01 AM
racin_40's Avatar
racin_40
ok then it is geared to run the 31's?
3.55gears
Old Mar 26, 2007 | 12:05 AM
jonnymagnum's Avatar
jonnymagnum
ya, mine has 31x10.5 with 3.55 from factory
