big rack and pinion question??? asap
Old Mar 26, 2007 | 05:46 PM
kfickel's Avatar
kfickel
Default big rack and pinion question??? asap
ok is the inner tie rod part of the rack and pinion??? cause i did replace the inner tie rod on the driver side which the inspectors did say it was the driver side leaking on the rack... im waiting for the rain to stop to go back out and looks ome more since i dont have a garage,,, but is their a special way to put a inner tie rod on?????
Old Mar 26, 2007 | 06:13 PM
Mike954's Avatar
Mike954
Default RE: big rack and pinion question??? asap
The inner tie rod is a part of the steering function but not necessarily part of the rack itself. The inner t/r is attached to the rack and most of the time when you buy a rack the inner t/r 's are included. But if your rack is leaking then the t/r's are not your direct problem. You will need a new steering rack.
Old Mar 26, 2007 | 06:54 PM
Chris's Avatar
Chris
ORIGINAL: Mike954
Agreed.
Old Mar 26, 2007 | 09:52 PM
kfickel's Avatar
kfickel
well im really asking if you replace the inner tie rod like i did not tighting right could that cause a rack leak???
