starting problem 2001 5.9 v8
Old Mar 28, 2007 | 11:47 PM
drakehunter1545's Avatar
drakehunter1545
Default starting problem 2001 5.9 v8
new to the forum, recently purchased 2001 dodge dakota 5.9 v8 4x4, had some rough running issues in beginning, engine codes helped me figure out that the 7&8 cylinder misfiring, changed all plugs and the two coils over the plugs. Now runs o.k once it's started, problem is getting started. I have to put it in the floor and crank till it starts, any ideas where to start. Usually starts right up warm, but if engine cools for more than 15 mins, hard to start again. Also exhaust smells real rich.
Old Mar 29, 2007 | 01:11 AM
varsis's Avatar
varsis
Default RE: starting problem 2001 5.9 v8
o2 sensor? or fuel filter is clogged or fuel injectors. If to the floor it seems to be either not getting enough gas, or too much or I say filter or injectors.
Chris
Old Mar 29, 2007 | 01:20 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
my 98 w/ 3.9 did almost the same thing, but mine would start ok w/o using the gas intermittenly, i would check the IAC valve on the back of the throttle body to see if it is clean and either clean, or replace it, but thats just my .02
Old Mar 29, 2007 | 04:24 AM
horatio102's Avatar
horatio102
Coil on plug? You sure you don't have a 4.7 and not a 5.9? If you don't have a quad cab, it's a 4.7
