Daytime running lights/Taking truck back to Canada!
Old Nov 17, 2009 | 11:25 AM
oakey134's Avatar
oakey134
Default Daytime running lights/Taking truck back to Canada!
I have an 04 Dodge Dakota quad cab that I purchased in Colorado but I intend to take it back to Canada with me next summer. The problem is it does not have Daytime running lights which are required in Canada. I had a dealership check the computer and there was not option to turn it on so Canada must use a different version in Canadian dakota computers also I believe there is a module that has to be installed that is not on the U.S. Dakotas. Can someone help with some advice here and also could someone with a Canadian Dakota take a picture of the module for me and a pic of where it connects to the wiring harness. I just want to make sure I can get the DRL installed when I take the truck up north.
Thanks
Old Nov 18, 2009 | 02:45 AM
Jdb107's Avatar
Jdb107
my truck is from canada, its always been insured in BC, ive had it for a long time with no one complaining, just passed aircare / vehicle inspection in january
it doesnt have daytime running lights
what province are you trying to take it into?
Old Nov 18, 2009 | 01:09 PM
oakey134's Avatar
oakey134
Nova Scotia
Old Nov 18, 2009 | 01:15 PM
tamcnally's Avatar
tamcnally
From: Salisbury, Vermont (home) - Lima, Ohio (school)
what if you just never turn your headlight switch off? because once you turn the key off the lights will shut off automatically. and then once you turn the key on the lights come back on. that should work for DRL's shouldnt it? just a thought.
