Help me decode my build sheet
Old Jan 15, 2015 | 03:57 PM
Dodgevity's Avatar
Dodgevity
Default Help me decode my build sheet
What the heck does some of this mean? I've bolded the few that I don't understand. Looks like my truck came pretty loaded but if there are desirable options missing, I have some u-pull-its nearby. Can you guys see some things missing you'd want?
"Next Generation Engine Controller"... why would this be optional?
Equipment Listing
VIN 1#################
Vehicle Description 2003 DODGE DAKOTA P/U QUAD CAB-SLT 4X2
Light Group
Monotone Paint
4 Wheel Disc Rr Anti-Lock Brakes
2nd Row 60/40 Bench Folding Seat
Next Generation Front Air Bags**
Front Seat Area Carpet
Passenger Assist Handle
Driver Assist Handle
All 5-Speed Automatic Transmissions
3.55 Rear Axle Ratio
Tinted Glass Windows
Tinted Windshield Glass
Front Door Tinted Glass
Deep Tint Sunscreen Glass
Rear Fixed Window
Driver Side Sun Visor
Passenger Side Sun Visor w/Mirror
Air Conditioning
Route 56 - NS, Hapeville, GA
Instrument Cluster w/Tach
120 MPH Primary Speedometer
Var Intermittent Windshield Wipers
Dual Note Electric Horns
STANDARD EQUIPMENT
1 09/17/14
12V Power Outlet Mounted in IP
BLACK - Badge - Dakota SLT
BLACK - BADGE - DODGE, TAILGATE
Halogen Headlamps
CHMSL Lamp
Bright Front Bumper
Bright Rear Bumper
Front License Plate Bracket
Bright Grille
Black Windshield Moldings
Gray Fascias
EVAP Control System
24 Gallon Fuel Tank
Bright Silver Metallic Clear Coat
4 Speakers
Fixed Long Mast Antenna
Power Rack and Pinion Steering
Heavy Duty Suspension
Front Heavy Duty Shock Absorbers
Rear Heavy Duty Shock Absorbers
Front Stabilizer Bar
Full Size Spare Tire
Tire Carrier Winch
Steel Spare Wheel
Pickup Box
Brake/Park Interlock
Build To U.S. Mkt. Specifications
GVW Rating - 6010#
U.S. Dealer Retail
2 09/17/14
Zone 66-Orlando
AN-Vehicle Family
Vehicle Order Tracking
U.S. Specifications Label
Georgia Ship to State Code
Georgia Sold to State Code
Cloth 40/20/40 Split Bench Seat
Dark Slate Gray
Heavy Duty Service Group
Trailer Tow Group
Deluxe Convenience Group
Power Overhead Convenience Group
Power Convenience Group
SLT Plus Decor Group
Mutually Exclusive Package
136 Amp Alternator
750 Amp Maintenance Free Battery
Cloth Door Trim Panel w/Map Pocket
Front Floor Mats
Overhead Console
5-Spd Automatic 545RFE Transmission
Lock-Up Torque Converter
Corporate 9.25 LD Rear Axle
4.7L V8 MPI Engine
Rear View Auto Dim Mirror
Power Heated Mirrors, Fold-Away
OPTIONAL EQUIPMENT
3 09/17/14
All Vehicles W/Power Mirrors
Keyless Entry
Power Locks
Power Windows, Driver One-Touch
Power 6-Way Driver Seat
EXTERIOR COMPONENT COLOR
Glove Box Lamp
Map/Dome Reading Lamps
Fog Lamps
Cargo Lamp
50 State Emissions
Power Steering Cooler
Speed Control
Heavy Duty Engine Cooling
All Radio Equipped Vehicles
AM/FM Compact Disc Radio w/Chgr Ctrl
Leather Wrapped Steering Wheel
Rear Stabilizer Bar
Tilt Steering Column
P255/65R16 OWL All Season Tires
Goodyear Brand Tires
16X8.0 Cast Aluminum Wheels
Class IV Receiver Hitch
7 Pin Wiring Harness
7 to 4 Pin Wiring Adaptor
Universal Garage Door Opener
Without Billable Fuel
4 09/17/14
Spring - Left Front
Spring - Left Rear
Spring - Right Front
Spring - Right Rear
Customer Preferred Package 2TH
Customer Preferred Package 26H
Customer Preferred Discount
BusinessLink Inventory
5 09/17/14
Old Jan 15, 2015 | 04:36 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
2003 was a transition year from JTEC to the NGC for many trucks (and cars). Depending on the drive train, it could be either one for that year. When looking in diagnostics or wiring, it will specify "NGC" or "GAS"
NGC also has 4 connectors, the 4th being the TCM that is integrated. JTEC only has 3.
CHSML is the third brake light
"Mutually Exclusive Package" Is that chick you met at the bar with the deep voice...that wasn't really a chick.
Old Jan 15, 2015 | 05:56 PM
Dodgevity's Avatar
Dodgevity
Talking
Well, I wish I wasn't drinking a soda when I read that last paragraph. I've got a clean up job to do now.
Thanks for the info. I wonder why the controller was listed under options?
Old Jan 15, 2015 | 07:55 PM
dodgeramguy85's Avatar
dodgeramguy85
Each model had their own set of codes as far as customer preferred packages. Might be able to get more answers if you call and ask them
Old Jan 16, 2015 | 11:46 AM
Dodgevity's Avatar
Dodgevity
What is this switch to the right of the shifter, just below the vents?
Old Jan 16, 2015 | 11:55 AM
00DakDan's Avatar
00DakDan
Section Moderator
Transfer case selector switch?
Old Jan 16, 2015 | 01:03 PM
dodgeramguy85
Selectable power switch... stock, semi stock and go baby go.....
electronic 4wd switch.
Old Jan 16, 2015 | 02:52 PM
Dodgevity's Avatar
Dodgevity
Originally Posted by dodgeramguy85
Selectable power switch... stock, semi stock and go baby go..... electronic 4wd switch.
Wish I had it. Ah well, I'm in Atlanta so.... snows maybe once or twice for the winter and then I drive my Accord.
Old Dec 11, 2019 | 09:28 AM
Michael JK's Avatar
Michael JK
Default Next Generation Controller
I was wondering about this NGC that became an issue when looking at O2 sensor listings. I found these charts on a site about engine building. Hope it helps someone.
File Type: pdf
File Type: pdf
