Ma girl ain't pullin !
Old 11-04-2015, 05:06 AM
Bigdiesel23's Avatar
Bigdiesel23
Bigdiesel23 is offline
Default Ma girl ain't pullin !
Yo got a 97 dak . 3.9 magnum. Check engines been on and off . Code is p0132. Upstream O2 sensor . Rich gas smell in the exhaust .hills are a bitch. Got no ***** after 75 mph . Not sure if it's plugs . The sensor . Or maybe the cat . Any clues guys
Old 11-04-2015, 07:45 AM
jkeaton is offline
Dodge Forum Administrator
How's the plenum? Clogged cat is always a possibility if the plenum is blown. Moving to the correct section.
Old 11-04-2015, 10:47 AM
HD Dakota's Avatar
HD Dakota
HD Dakota is offline
the up stream o2 is what adjusts fuel and air, that would effect performance. as for the cat if it was plugged, you would have problems with the down stream o2 it checks if your cat is working.
Old 11-05-2015, 08:48 PM
magnethead's Avatar
magnethead
magnethead is offline
Replace the upstream would be a starting point. If you can smell fuel, it's stupid rich. Could have a stuck injector as well.
Quick Reply: Ma girl ain't pullin !
