03 durango pw work intermittently
Old Jan 24, 2017 | 08:34 PM
MC_Dodge's Avatar
MC_Dodge
Default 03 durango pw work intermittently
03 durango, all the power windows except for the drivers have basically stopped working. the problem grandually got worse - i'd roll the windows down, and sometimes they wouldn't roll up; then over time, most of the time they would not roll up. now i'm afraid to roll any of them down. when they worked, they worked fine, meaning they weren't slow to roll up.
Old Jan 24, 2017 | 11:40 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Check the voltage on circuitt Q1, the yellow wire. It's possible you could have a master switch issue also. I wouldn't suspect ground because all 4 use the same path back through the master switch and since your drivers window works fine....
Old Jan 28, 2017 | 10:01 AM
patchelect's Avatar
patchelect
Somewhere on this forum I found a method of putting a jumper on the child proof switch on the drivers door. My intermittent, most never, passenger window switch has been working fine ever since. I think it's that point marked "9 Lockout" on the drivers door section of the first part of the diagram shown.
