2nd Gen Durango 2004 - 2009
Rear window Wiper Blade Install Questions
Old Oct 26, 2007 | 12:50 PM
xray328's Avatar
xray328
Default Rear window Wiper Blade Install Questions
Hi guys. I'm trying to replace to wiper on the rear window, but it's like nothing I've ever seen. It's like the mount is permanently attached to the wiper arm. I tried just pulling the rubber off the new blade, minus the metal mount, and slide that in there, but its too big. Any ideas?
Thanks in advance.
Old Oct 26, 2007 | 04:39 PM
sca's Avatar
sca
Default RE: Rear window Wiper Blade Install Questions
There is a clip tu push down or in on the underside of the arm. Once pressed you can pull the whole arm off.
I have been told the replacement from the dealer is not that expensive.
Old Oct 27, 2007 | 12:52 AM
xray328's Avatar
xray328
So this is something you have to order through the dealer??? I gotta order a wiper blade through Dodge? [sm=icon_flaming.gif]
Old Oct 28, 2007 | 06:31 AM
IndyDurango's Avatar
IndyDurango
Its a 2 piece blade. Don't mess with it at the pivot post, jus tthe second section needs to come off. Very easy, should take 10 seconds to look at it and understand how the other section comes off. Yes, since it is special and a 2 part product, you need to get that second part from the dealer.
IndyDurango
