2nd Gen Durango 2004 - 2009
Help! Only one wiper works!
Old Jan 15, 2008 | 07:51 PM
swolfe9's Avatar
swolfe9
Default Help! Only one wiper works!
On my 04 Durango, only one of my wiper blades is working..what could be the problem?
Old Jan 15, 2008 | 08:07 PM
Duranged408's Avatar
Duranged408
Default RE: Help! Only one wiper works!
If they still operate as the older, the driver side operates the passenger side via rods. And if so chances say something came undone or the wiper arm is stripped. ( If the wiper was stripped some movement would still occur. Everthing should be under the cowl
Old Jan 15, 2008 | 10:56 PM
onephatcracka's Avatar
onephatcracka
its a ball and socket design on those rods. the plastic might be worn out or as duranged408 said. it might have just popped out
Old Jan 17, 2008 | 08:06 PM
swolfe9's Avatar
swolfe9
Thanks for the help...I had it looked and and the bolt was loose that holds the arm on...glad that's all it was!
