2nd Gen Durango 2004 - 2009
keyless remote
Old Feb 8, 2008 | 10:52 PM
highstick72's Avatar
highstick72
Default keyless remote
Quick question I disconnected the battery and the remote stopped working does anyone know how to reset it?
Old Feb 9, 2008 | 08:15 AM
Wishbone's Avatar
Wishbone
Default RE: keyless remote
1. Enter your vehicle and close all doors.
2. Fasten your seat belt (Fastening the seatbelt will cancel
any chiming that may confuse you during this programming
procedure).
3. Place the key into the ignition.
4. Turn the ignition to the ON position (
Do not start the
engine
5. Press and hold the UNLOCK button on the key fob.
6. After holding the UNLOCK button for four seconds,
also press the PANIC button within 6 seconds.
7. When a single chime is heard release both buttons. The
chime is an indication that you have successfully entered
program mode. All fobs that are to be programmed must
be done so within 60 seconds of when the chime was
heard.
8. Using the fob to be programmed, press and release
both the LOCK and UNLOCK buttons, simultaneously.
9. A single chime will be heard.
10. Within four seconds of hearing the chime, press and
release the UNLOCK button on the fob.
11. A single chime will be heard.
12. Repeat steps 8 through 10 to program up to six
additional fobs.
13. Turn the ignition to the OFF position.
14. Your vehicle will remain in program mode up to 60
seconds from when the original chime was heard. After
60 seconds, all programmed fobs function normally.
2
Old Feb 9, 2008 | 09:09 AM
highstick72
Thank you so much!! This is a great site.
