2nd Gen Durango 2004 - 2009
Adjusting headlights
Old Feb 22, 2008 | 12:31 PM
tootnjack's Avatar
tootnjack
Default Adjusting headlights
I put a 3" Ready Lift in my 07 Durango. Is there a way I can adjust my headlights so people don't think i'm bright lighting them?
Old Mar 10, 2008 | 12:49 AM
spfd308's Avatar
spfd308
Default RE: Adjusting headlights
raise the hood inside of the headlights there is a little star head screw. just get the right size torx and turn it. don't remember what size it is but i adjusted mine on my ram and on a buddies ram. also did my wife's 06 durango.
Old Apr 29, 2009 | 10:18 AM
rbenkemeadow's Avatar
rbenkemeadow
On my 06 durango there's no way to access the headlight from under the hood. I put HID's in and need to lower the beam.
Old May 4, 2009 | 10:52 AM
rbenkemeadow
Anyone?
Old May 6, 2009 | 11:32 AM
TJL's Avatar
TJL
Below the headlight, between the bottom of the headlight and the bumper if you take a flashlight you will see a torx screw. Turn that torx and you can raise and lower the beam.
Good luck,
Todd
Old May 6, 2009 | 11:45 AM
rbenkemeadow
I had the headlights on the garage the other night and started to turn the screw and noticed 2 things. The beam was not moving and the screw seemed hard to turn also.
