2nd Gen Durango 2004 - 2009
installing a grill guard on 06 durango
Old Feb 25, 2008 | 06:22 PM
pauldid's Avatar
pauldid
Default installing a grill guard on 06 durango
I just bought an after-market grill guard and I am trying to install it but there are two existing bolts on my Durango that I can't seem to figure out how to remove. The instructions for the grill guard say that I need to remove and reuse those bolts during the install. The bolts are just behind the bottom of the front bumper, one on either side. I have even tried an impact wrench which will not unscrew the bolts. They will turn with effort using a breaker bar and are not frozen or rusted stuck. They just won't come loose. Does anyone know what the trick is to getting these two bolts off? I have included a picture of one of the bolts so you can see what I am talking about.
Thanks,
Paul
[IMG]local://upfiles/84751/420544FB0BDD4276B1906982AD230E6C.jpg[/IMG]
Old Feb 26, 2008 | 09:19 AM
MrNobody's Avatar
MrNobody
Default RE: installing a grill guard on 06 durango
So you bought a cow pusher. Nice. Is it a full or a 1/2? I'd like to see some pics when you get it done. Also try your local body shop or dealer, they should be able to point you in the right direction.
MrN
Old Feb 26, 2008 | 01:52 PM
pauldid's Avatar
pauldid
May have found the answer to this problem over on dodge talk.com if you are having the same problem read this http://www.dodge talk.com/forums/showpost.php?p=702093&postcount=17
I am going to give this a try tomorrow and see if I can get these bolts off.
Paul
