SCT Tuner for 04-06 Durango's
My Durango is running with SCT tuning for the past 3 weeks!
All I can say is WOW!
I had a Jet Stage 1 Chip, B&G Custom Flash and now SCT tuning from Hemifever.
Truck is a whole new animal! Huge power throughout the whole rpm range!
http://www.youtube.com/watch?v=VPg4krUFpeY
That is pretty sweet. That was in kph right? What are your 0-60 times. Do you know what your hp is to the wheels is and total for your engine output. You hit about what 105 mph. I know it's not your top speed but what does it top out at? Plus were you able to adjust your rev limiter and shift points? If you can't tell I am interested in upgrading mine more too.
ORIGINAL: 1BADHEMI
MrN
-shift points are at 5800 rpm in auto if I shift manual at 6500 rpm (rev. limiter)
-top speed is set at 140 mph
-0-60 should be in the 6.5 second range
-wheel HP I estimate +325 HP
-engine HP I estimate 450 HP
-would love to go on a dyno but I have not been able to find a 4X4 dyno in my area, next one is 6 hours away
-will go on a 1/4 mile track to get some data that has value, would guess low 14's
On top of all that great power I have an increase of 1.5-2 mpg's
http://sctflash.com/
My tuner is "Hemifever" from KRC Tuning. He is a great Guy, very knowledgeable!
You get the tunes by e-mail and load them into your PCM via a handheld tuner.
You need to know your PCM# they are all different, only way to find out is to take the PCM out.
Easiest way is going through the passenger side front fender, you have to take out the fender liner.
Shouldn't take more than an hour to do. Once you have that you program through the OBD port.
