2nd Gen Durango 2004 - 2009
Fluid Leak
Old Mar 30, 2008 | 08:52 AM
haywardg's Avatar
haywardg
Default Fluid Leak
I own a 2005 Durango 5.7 Hemi...I recently noticed a small amount of what I believe is oil on my garage floor. It is not red so I don't think it is tranny fluid but am not sure. Came from toward the front of vehicle. Could someone advise me what might be causing this or anyone with this same situation?
Old Mar 30, 2008 | 10:01 AM
wicked_5.7Hemi's Avatar
wicked_5.7Hemi
Default RE: Fluid Leak
"Came from toward the front of vehicle."
i have exactly the same thing on mine... i brought it to the dealer and the problem was from the power steering wheel hose... good thing i thing mine is still under warranty... they've ordered the part which has arrived and will be installing later today...
Old Mar 30, 2008 | 10:16 AM
haywardg's Avatar
haywardg
I was leaning toward that same conclusion...I believe my warranty is expired, 43000 miles, do you know the cost without warranty?
Old Mar 30, 2008 | 10:23 AM
wicked_5.7Hemi
Sorry... I have no idea...
Old Mar 30, 2008 | 06:53 PM
n8ech's Avatar
n8ech
hayward:
Could be anywhere from $50 to ?????? If your steering rack is leaking, that costs a buch especially if the dealer does it. If the leak turns out to be engine or tranny related, your 7/70 powertrain warranty should cover it with a $100 deductible.
Whatever you do though, I would not wait around until whatever is leaking completely fails and leaves you stranded.
Don
Old Apr 7, 2008 | 05:15 PM
haywardg's Avatar
haywardg
Just a head's up, ended up being a gasket on the tranny pan. Had to replace filters, fluid, etc. $100.00
Old Apr 8, 2008 | 12:23 PM
n8ech's Avatar
n8ech
Hayward:
Glad to hear the issue was covered under your 7/70. This may be a blessing in disguise as now you have had your tranny serviced. Don't forget though about your transfer case (if 4x4) and axle fluids. These also should be done as well. IIRC, the Gen 2 T case can wait till 50k, and the axles are still 30k.
Don
