2nd Gen Durango 2004 - 2009
2004 - Radio barely lit and wont play
Old Jan 5, 2005 | 04:45 PM
chrisindfw's Avatar
chrisindfw
Default 2004 - Radio barely lit and wont play
My radio in my 04 durango has become barely lit and will hardly play. It does it every now and then. Turning it off and on again will fix the problem but today it did not fix it. After work I will unplug the battery and see if that does the trick. You cant see anything however the station that was on it before is on but barely able to be heard. The screen is dark with red-like lines through it. You cant change the station, cant switch between cd and radio. Its stuck.. Help.
Old Jan 6, 2005 | 04:48 PM
jasonwyo's Avatar
jasonwyo
Default RE: 2004 - Radio barely lit and wont play
warrenty = dealer fix
