2nd Gen Durango 2004 - 2009
2004 Durgano 4x4
Old Apr 19, 2008 | 10:47 PM
tinyg's Avatar
tinyg
Default 2004 Durgano 4x4
Hi I have a Durgano 2004 4x4 and went to change tire and I cant get the wheel off it seems to be stuck to it looks like a sleeve. I read the manual and all it said was remove 5 lugs and take wheel off. I never had a problem with other cars but never had a 4x4 neither please help.
Old Apr 23, 2008 | 09:45 PM
n8ech's Avatar
n8ech
Default RE: 2004 Durgano 4x4
Tiny:
Sounds like you have some corrosion between the wheel and the rotor or drum.
You will need to get a rubber mallet or good sized cheater bar and give the wheel a good rap on the back side of the rim. A few good blows should breakit loose.
Be sure to have the vehicle well supported before you start pounding.
Good luckDon
