Looking for trailer lights and electric brake wires
If you have the tow package,everything shoud be their. if you don't have the tow pacage then you will need to wire to the ligts you need,and install a 7 way plug if you want brakes,but I think you'll need a hot wire from the battery for the brakes. I'm not electrical so I would take it somewhere to have it installed,if it were me.
Jake76
Look some where round the rear bumper on the driverside there should be a factory harness. If not then you might need to tap from the rear lamp electical wire for the stop, parking light and signal.
If using with brake controller like DURANGOJ said you need to run the hot wire direct from the battery with inline circuit breaker I believe 30amp.
Okay I found a blue plug under the black cover where thepedal adjustbutton would be if I had one. Is this the plug I'm looking for or is that for the pedal adjust?
