2nd Gen Durango 2004 - 2009
Dual Exhaust System Durango 08
Old May 22, 2008 | 02:03 PM
MEINEKEMAN1's Avatar
MEINEKEMAN1
Default RE: Dual Exhaust System Durango 08
ORIGINAL: Joeecko
I had a flowmaster muffler put on with a set of dual custom pipes on my 07 durango,you have plenty of room my friend.look around in your area for custom shops.
This is exactly right.I do custom dual at my shop every day.Just find a shop in your area that has a good reputation for custom exhaust and they will give you the options available to you.
The spare tire won't be a problem at all.Tail go around it.
Old May 22, 2008 | 02:05 PM
MEINEKEMAN1
ORIGINAL: MEINEKEMAN1
ORIGINAL: Joeecko
Oh yeah and if you don't wantanything to loud inside the cab arear,I would go with a 70 series Flowmaster.Still more flow and hp,just less noise inside.
Old May 22, 2008 | 07:58 PM
atov's Avatar
atov
1badhemi thanx for the advice ... i'll check it out ... About the catalitic converter, it doesnt matter where I live. So if I take it out, would I get better sound o what would happen?
Al.
Old May 23, 2008 | 07:46 AM
MEINEKEMAN1
ORIGINAL: atov
Al.
You may not need an emissions test where you live,but any vehicle that requires a converter to be on,still must have one to pass inspection.Unless you have someone that will do it for you.
As far as removing it,you will get more sound,but you will also be losing your low end hp/torq.You need some backpressure for the engine to work the most efficiently.
Why not just look into getting a high flow converter?
Old May 23, 2008 | 12:03 PM
atov's Avatar
atov
So the best option is to get a High Flow Converter right ?
Old May 24, 2008 | 09:53 AM
MEINEKEMAN1
ORIGINAL: atov
Yes sir.That way,you're still legal and getting the hp and sound upgrades that you are looking for.
Old Jun 16, 2008 | 07:57 PM
atov's Avatar
atov
between a Flowmaster 50 series Delta Force and a Flowmaster Super 40 ??
