2nd Gen Durango 2004 - 2009
stored code p2299
Old May 27, 2008 | 03:46 PM
DURANGOJ's Avatar
DURANGOJ
Default stored code p2299
I have an 08 durango with the hemi. I have a stored code 2299. I found it by the key on/off method. does anyone know what this code is. Thanks in advance
Old May 27, 2008 | 10:55 PM
Parts/Service's Avatar
Parts/Service
Default RE: stored code p2299
P2299-BRAKE PEDAL POSITION / ACCELERATOR PEDAL POSITION INCOMPATIBLE[*]Set Condition:
The PCM recognizes a brake application following the APPS showing a fixed pedal opening. Temporary or permanent. Internally the PCM will reduce throttle opening below driver demand. One trip fault and the code will be set within 5 seconds. ETC light will illuminate, the light will only stay illuminated while DTC is active.
Possible Causes
CUSTOMER PRESSING ACCELERATOR PEDAL, THEN PRESSING BRAKE PEDAL, AND CONTINUES TO HOLD THEM DOWN SIMULTANEOUSLY
STOP LAMP SWITCH
APP SENSOR
note:If a pedal assembly becomes mechanically stuck the voltage output will stay fixed, if this is also Followed by a long application of the brakes this code will set.[*][*]note:When this code sets the pedal position in the PCM software will ramp to idle. If the Pedal voltage changes OR the brake pedal is released, the pedal position in the PCM software will ramp up to the pedal position and the ETC light will go out.[*][*]NOTE:The most likely cause of this DTC is caused by the customer Brake Torquing the engine by pressing the Accelerator pedal and the pressing the Brake Pedal.[*][*][*]Hope this helps.....
Old May 27, 2008 | 11:52 PM
DURANGOJ's Avatar
DURANGOJ
Thank you
Old May 28, 2008 | 08:39 AM
sca's Avatar
sca
good info....I had that pop up several times when my truck didn't idle properly...
