2nd Gen Durango 2004 - 2009
axle ratio? 3.55 or 3.92?
Old May 30, 2008 | 10:57 PM
tlarimer's Avatar
tlarimer
Default axle ratio? 3.55 or 3.92?
I just bought my wife an 08 Durango Limited 4x4 with the Hemi. I am curious if it has the 3.55's or the 3.92's, where can I find the axle identifier? Is it located on a tag somewhere on the vehicle? It doesn't say on the window sticker and we are looking at a trailer, but want to know for sure on the axle ratio, so I can determine the towing capacity. Thanks guys.
Old May 31, 2008 | 07:58 PM
DURANGOJ's Avatar
DURANGOJ
Default RE: axle ratio? 3.55 or 3.92?
The 3.55 is the standard. 3.92 is an option. call your salesman he can pull up the build sheet,and tell you. also look in your glove box. may be in there as well.
Old Jun 2, 2008 | 10:39 PM
n8ech's Avatar
n8ech
Larimer:
Also try looking behind the driver side rear wheel for a small white label wrapped around the axle tube. If there, it should tell you the ratio.
Don
Old Jun 7, 2008 | 06:24 PM
tlarimer's Avatar
tlarimer
Thanks for the replies, There are no labels on the durango. Dodge customer service emailed me back and told me the buildsheet stated 3.55's. Thanks guys.
Old Jun 10, 2008 | 08:52 PM
superdak05's Avatar
superdak05
the other place to check is the back of the glove box, there should be a sticker saying what it is and other options
