2nd Gen Durango 2004 - 2009
Keyless stopped working
Old Jun 30, 2008 | 10:35 AM
dylyttle's Avatar
dylyttle
Default Keyless stopped working
I purchased a 2005 Dodge Durango just over two months ago. Both my remotes have stopped working, and of couse I am out of warranty. I tried the reprogramming listed in the manual, but no success. Can anyone help?
Thanks
dylyttle
Old Jul 1, 2008 | 12:13 AM
n8ech's Avatar
n8ech
Default RE: Keyless stopped working
dy
There is a fuse you can pull, and it may reset the keyless entry module. Don't know which one it is, as I have a Gen 1 D. Check your owners manual and give it a try.
Don
Old Jul 5, 2008 | 08:21 AM
Flounder044.7's Avatar
Flounder044.7
Both my key fobs quit too. The problem is the battery holder in the fob. There are contacts that come loose on the metal clip that holds the battery to the board. I resoldered both of mine and have not had any problems in the past few years.
Take yours apart as if you were going to change the battery and see if this clip is loose. If it is resolder it to the board and you will be good to go.
Of course I figured this out after dropping $100 at the dealer for a new key. [sm=headbang.gif]
