2nd Gen Durango 2004 - 2009
Which Transmission, Transfer, and Diff?
Old Jul 11, 2008 | 08:43 PM
m00se's Avatar
m00se
Default Which Transmission, Transfer, and Diff?
I have a 2005 Durango SLT, 4.7l. How do I determine which transmission, transfer case, and diff I have?
Thanks in advance for your help.
Old Jul 12, 2008 | 10:36 PM
n8ech's Avatar
n8ech
Default RE: Which Transmission, Transfer, and Diff?
Hi Moose:
All Gen 2 Durangos have the 545rfe transmission. Your rear axle should be an 8.25 inch unit as all of the 4x4 Durangos had these from 2004 on. The 4x2 D's had the beefier 9.25 rear as being 2wd the rear axle has to be able to handle 100% of the engine power/torque.
Your T case is a bit more tricky. What does the **** on your dash say?? If it says AWD and 4HI, you have the single speed NV144 case, and if it says AWD, 4HI, and 4LO you have the two speed NV244 case.
Don
