Durango 2nd Gen O2 wiring harness
I have a 2004 Durango with a hemi engine. I received error code P0038 for the Bank 1 Sensor 2 O2 sensor. I understand that is on the driver side behind the cat. I need help in finding out how to get to the wiring harness. I can see it clearly but it is located high above both the exhaust and drive shaft and there is no way I can get my hand up there to disconnect it. Does the driveshaft have to be removed to reach the wiring harness? It looks like there would be a similar problem for the front sensor. (My car has 4 sensors!)
Help! David
Help! David
