2nd Gen Durango 2004 - 2009
Problem with Drivetrain
Old Mar 26, 2009 | 04:25 PM
robmagix's Avatar
robmagix
Default Problem with Drivetrain
I have an 05 D 4.7 with a thump when ever I hit the gas pedal.
It never happens while in between 0-15 mph. but it happens every other time.
Once the truck slows down then I hit the gas I get the thump.
Dealership keeps telling me it's normal for the 2nd gen D.
i've been fighting with the dealership for two years.
Old Mar 26, 2009 | 09:30 PM
DragonOfMadness's Avatar
DragonOfMadness
Don't forget about a loose pinion yoke or transfer case yoke{also probably covered in Hydra's u-joint answer but I'll ask anyways}check the tranny mount, and does it do it with the vehicle in 4wd on Mark's question and a possible torque converter problem on Rob's=does the truck shift funny? and did you have the fluid changed recently?
and does it do it with the overdrive off?how bout in 4wd?
Old Mar 26, 2009 | 11:19 PM
hydrashocker's Avatar
hydrashocker
Yes I'm thinking a U-joint.
Take it to a different dealer befor you warranty goes out!
Old Mar 28, 2009 | 12:30 AM
dodgeit100's Avatar
dodgeit100
my wife had a similiar problem in her 06 durango she took in and had to have the transmission recalibrated and updated. you might wanna try that along wiht the other suggestions.
Old Mar 29, 2009 | 08:43 AM
04Hermi's Avatar
04Hermi
Get under the truck and rotate the driveshaft back and forth (actually wiggle it back and forth, y'know left right left right) and if you can feel is clunkin its a U-joint.
Old Mar 30, 2009 | 01:21 PM
robmagix's Avatar
robmagix
Hello everyone;
I will check on all of your suggestions, I will post if I am able to find the problem.
