Rear air doesn't blow hot or cold...
My rear air will not respond to cold or hot settings from either the rear control panel or the front control for the rear air. The front a/c and hear work fine, but the rear just blows air, not hot or cold, when set to the respective settings.
flapper door maybe?
flapper door maybe?
Yes - broken flapper door. I wound up buying a whole new rear hvac unit real cheap from someone parting out a really low mile wreck. Haven't put it in though.
I have a 2004 Durango with no rear heat. Both selenoid that actuate the door were not making contact. I bent back into position, but I have the broken blend door. Is there a way to fix this without draining the coolant/refrigerant and lifting the vehicle(according to manual)?
I was hoping a dremel and epoxy could get this working as opposed to the money the dealer would charge to fix a plasic door.
John
John
