2006 Durango foglamps and rear wiper
My foglamps and rear wiper dont work properly. I was just wondering if anyone else has had any issues with these. There is power to all of the fuses for the fog lamps, but I havent pulled the relay to check it yet. And my rear wiper only has one speed. And if it is the first time you use it for the key cycle, then it will wipe a few times then when it should be going to the rest position, it stops somewhere up on the glass. After the first use, it just keeps going till you turn it to the off position. I assume that Im going to need a new wiper motor, But before i buy one, has anyone else had this issue?
2006 should be still under warranty. Take it to the dealer and have it reviewed. No reason to guess at it when it's electrical related.
There was a recall on odd electrical issues under the dash. Yours may be affected.
IndyDurango
IndyDurango
