2nd Gen Durango 2004 - 2009
04 Durango Limited almost got away from me...
Old Aug 2, 2009 | 06:33 PM
The Hurse's Avatar
The Hurse
Exclamation 04 Durango Limited almost got away from me...
Me and the wife are going out for some sunday shopping. Hop in the truck, flip the key, let the guages do their self check, wife hits the A/C, and i start the truck. Put my foot on the brake, put it "D" and she (the truck) starts bucking like some kinda rodeo, then stalls. Weird I think to myself. Put it back in Park, start it again, it starts, then stalls. Does this 2 more times (stalls). Finally I start it, give it some throttle and shes fine. I drive about 20 ft. Decide to try to see if I can duplicate that bucking and stalling again but it doesnt work. Anyone ever had that happen? No CEL's, and I cant figure out how to see if there is a code being thrown. See my other post regarding the (key flip). Thanks..
Old Aug 2, 2009 | 09:37 PM
hydrashocker's Avatar
hydrashocker
Here is the info. You use the ignition key tumbler back and forth to get the codes.
https://dodgeforum.com/forum/1st-gen...ine-light.html
Could be a Throttle Position Sensor going out.
2000 and newer directions:
Turn the key to ON (not start), OFF, ON, OFF, ON and leave it there. If you look in the odometer window the codes will flash any code(s) with a small delay between each result. Each code should be in a P#### format, and will say PDONE when completed - turn your key to OFF and remove. Use the OBD code list to determine what problem the computer detected.
