2nd Gen Durango 2004 - 2009
2006 Durango Lift kit
Old Dec 23, 2009 | 03:40 AM
flyboy1304's Avatar
flyboy1304
Default lift kit
I'm actually looking into buyina a Durango, Currently i own a 2006 dakota... about to have a 3rd kid. so we need the room. Everything that was posted is 100% correct. I've done alot of reading and searching... This only "lift" i found was a 2.25" leveling kit that will alow you to fit 33's. It will maintain your factory ride "quality"... I havent driven in a 2nd gen durango yet, I dont know the ride quality is. I can tell you that i have a leveling kit on my dakota it actually improved the ride quality. The dakota and durangos have different front ends. Nothing is interchangeable. Yes you can crank up the torsion bars, however I have been told it wears out your front end prematurely. Also it stiffens the ride... If your fine with that do that. I can tell you that the ride quality on the 3rd gen Dakota suck its improved when you put the leveling kit on it and it stiffend it up a little. Hope this helps...
Old Jan 6, 2010 | 12:58 PM
bluedurango123's Avatar
bluedurango123
Wow very nice. i just got the leveling kit(torsion keys, and i no people say there junk but i have had no problem.) put on my 05 D, i can fit 33'' but want 35'' no of anyway i can do that because i cant find a lift kit any were ?
Old Jan 8, 2010 | 04:50 PM
Durangonut's Avatar
Durangonut
Thanks for all the info i will be lifting mine when the snow clears.
Old Jan 9, 2010 | 08:59 PM
Duratron's Avatar
Duratron
The keys from truxxx claim with a slightly offset rim you can fit 35 with no issues.
http://www.truxxx.com/product/dodge
Old Sep 12, 2012 | 12:34 AM
Akin Richardson's Avatar
Akin Richardson
Hey if u do find one could u please let me know where u got it cause i have an 06 rango and i cant find a lift kit for it either.
Old Dec 30, 2012 | 12:50 AM
Tristan33w's Avatar
Tristan33w
Originally Posted by Duratron
10 min job in your very own driveway...if you level it right out (between5-6 full turns) you will need an alignment done.
I turned mine 5 turns.
Did you paint the top of your headlights? And also the grille? If you bought those then where from?
Old May 1, 2013 | 11:21 AM
JosephTaunton's Avatar
JosephTaunton
duratron your D looks real nice I also have a 06 and I leveled it off with the torsion I was wondering if any knows if I can drop my rim size to a 16
Old May 2, 2013 | 08:49 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
The rim size will remain basically the same if you go to a 16" wheel.
Old May 2, 2013 | 11:34 AM
JosephTaunton
im not following you thats a inch difference the 06 come stock with a 17 i wanted to know if any one has fit a 16 with out grinding the caliper
Old May 5, 2013 | 09:54 AM
1969CoronetR/T
vaffanculo
I thought you were asking about the rim size, not the wheel size. The rim is a part of the wheel on the outside face of it that holds the bead of the tire onto the wheel.
