2nd Gen Durango 2004 - 2009
Front control arm replacement procedure
Old Sep 21, 2009 | 03:14 PM
rodmodder's Avatar
rodmodder
Default Front control arm replacement procedure
Anyone have the procedure for replacing the front control arm/ball joints for a 2004 durango 4x4, 5.7L ?
Is alignment immediately necessary?
Old Sep 21, 2009 | 11:23 PM
IndyDurango's Avatar
IndyDurango
When you replace the BJs, yes you need to get it aligned within a day or so. No real distance driving should be done before hand.
IndyDurango
Old Sep 22, 2009 | 07:46 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Check out Hydrashockers thread about 4x4 alignment:
https://dodgeforum.com/forum/1st-gen...ment-woes.html
It is on a first generation Durango, but it still holds true,
FF
Old Sep 22, 2009 | 03:21 PM
rodmodder's Avatar
rodmodder
Great, what about the procedure for removing the control arms?
Old Sep 22, 2009 | 07:49 PM
1969CoronetR/T
vaffanculo
There is another thread for the first generation Durango concerning ball joints:
https://dodgeforum.com/forum/1st-gen...ll-joints.html
Otherwise there is a 'search' field in the black menu bar at the top that may help you further,
FF
Old Sep 28, 2009 | 02:39 PM
autotech2's Avatar
autotech2
It's a pretty simple job if you know how to break ball joints and tie rod ends loose. Just remember to jack it up by the frame, back off on the torsion bar adjuster, and back the torsion bar out of the lower A-frame, before you do anything. And mark where the adjuster was so you can tighten it back to where it was.
