2nd Gen Durango 2004 - 2009
Durango rear heat not blowing heat
Old Jan 1, 2010 | 05:24 PM
DPFIRE29's Avatar
DPFIRE29
Default Durango rear heat not blowing heat
FIRST OF TWO PROBLEMS IS THAT THE FRONT BLOWER ONLY WORKS ON HIGH SETTING THE SECOND IS THE REar works on all settings but only blows cold air, the setting is on hot both front and rear, dont know what to do can someone help
Old Jan 1, 2010 | 09:49 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Repost this in the first or second generation Durango section (whichever applies to your vehicle) as this is the general forum,
FF
Old Jan 5, 2010 | 03:59 PM
tm985's Avatar
tm985
weird, I would like the answer to this because I Just noticed this issue with mine as well.
Old Jan 5, 2010 | 06:41 PM
1969CoronetR/T
vaffanculo
I believe it could be the blend door. Here is a link:
https://dodgeforum.com/forum/1st-gen...rely-warm.html
There is a search function in the black menu bar on top that you can type 'blend door durango' or 'no heat durango' for more threads that may help,
FF
