2nd Gen Durango 2004 - 2009
Brake light and ABS light on
Old Feb 10, 2010 | 07:33 PM
boysnblu's Avatar
boysnblu
Default Brake light and ABS light on
I have a 2006 Durango and a month ago my dash lights of the Brakes and ABS came on and will not go off. I check the fluid level was ok, I just finished replace the brake pads. They were still on so i was told about the rear wheel speed sensor. I repalced both in the rear today (feb 10). Lights were still on and i even drove if a few miles, still on. Not sure if the speed makes a difference or not, never left the neighbor. so 30 was the most i got up to. I also had the local parts store (auto Zone and advance) get computer to it and no codes came back. losing my mind and do not want to spend and arm and leg at the dealership. PLEASE help anthing i can try. I can not get my truck inspected in my state because of the light on the dash and now i am expired just waiting for a ticket.... ANY IDEAS
thanks
Old Feb 10, 2010 | 07:55 PM
MrKiLLTER's Avatar
MrKiLLTER
Have you tried diconnecting the battery/
Old Feb 10, 2010 | 08:44 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
do what MrKiLLTER said by disconnecting the negative terminal on the battery for a few minutes and see if it clears up,
FF
Old Feb 11, 2010 | 12:07 AM
boysnblu's Avatar
boysnblu
yes i have also tried disconnecting the battery and pump the brake pedal, nothing changed lights still on
Old Feb 14, 2010 | 12:09 AM
xoxomistyxoxo's Avatar
xoxomistyxoxo
I had the same problem with my 07 Durango. After the dealer replaced my instrument panel 3 times because they thought it was in the wiring. My brakes failed and it was the master cylinder and the booster they couldn't find it until it completely failed then the comptuer detected the problem.
Good luck hope things go better for you than they did for me.
