2nd Gen Durango 2004 - 2009
Changing Headlights
Old Feb 16, 2010 | 05:23 PM
Brian5926's Avatar
Brian5926
Default Changing Headlights
Probably a really dumb question..... I bought some new headlights and can't get them in, how to I access the headlight housing? It seems that I cannot get to it through the engine compartment. Do I need to come up from underneath, will anything need to be removed?
Thanks
Old Feb 16, 2010 | 09:22 PM
staniks's Avatar
staniks
See if this helps
http://www.ehow.com/how_4520906_repl...e-durango.html
Old Feb 17, 2010 | 07:58 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
THere is a 'window' panel in the front wheel well behind the headlight. If you look at your front tire it will be directly in front of it in the nine o'clock (driver side) and three o'clock (passenger side) position. You have to turn the wheel to access it as it is in the way and you will need an adapter to reach the bolt behind the panel to loosen the headlight,
FF
