2nd Gen Durango 2004 - 2009
HELP!!! Repeated loss of low beam ONLY light.
Old Oct 11, 2010 | 01:42 PM
brainpa's Avatar
brainpa
Default HELP!!! Repeated loss of low beam ONLY light.
On my 07 Durango, I've have lost the low beam on my drivers' side lamp. I changed out the entire bulb, SAME problem.
Neither my Drivers' Manual nor the fuse box cover[s] give a location for the headlights fuse, and, of course, when asked, the dealership won't tell me. "Just bring it in".
ANY advice would be appreciated. Getting ready later today to change out the entire lighting harness to an after market brand in order to run upgraded bulbs which draw more then the OEM ones can support.
Thanks, and I'll be checking back frequently.
John
Old Oct 17, 2010 | 11:26 AM
Elchulachaser's Avatar
Elchulachaser
Does the Left side low beam blow out or just go out?
I have the same problem with my 04 Durango and it turns out to be the plug. With the lights on and the wheel turned to the extreme rigt, you can remove the wheel-well access hatch to get to the bulb. When I push the plug in the low beam comes back on but once I release pressure on it it goes back out. In my situation I have to replace the actual greem bulb plug.. Just a big PITA since it has short wiring..
Cheers,
Chris
