2nd Gen Durango 2004 - 2009
Largest Wheel Size
Old Jun 4, 2005 | 03:13 AM
CIAgentx's Avatar
CIAgentx
Default Largest Wheel Size
What is the largest size tire/wheel combination I can put on my 04 Limited Durango, without lifting it or have to worry about trimming or rubbing?
I want to have that off-road-monster-truck-look, instead of the current soccer mom look....
Any info would help and if anyone has a picture, that'd be even better! Thanks in advance!
Old Jun 24, 2005 | 05:00 AM
datboimell's Avatar
datboimell
Default RE: Largest Wheel Size
well the largest size ive seen so far would be the 22's my dad pu ton his........with no modifications to the suspension or rubbing or anything......................
Old Jun 25, 2005 | 02:07 PM
Last Of The R/Ts's Avatar
Last Of The R/Ts
Well if you are going for the off-roading hillbilly look I wouldn't be able to help you there but if you are going for style, you can fit 23" rims/tires with no modification at all. I have seen 24" rims on the new Durango but it did require some minor trimming.
