2nd Gen Durango 2004 - 2009
04 5.7 burning engine oil?
Old Dec 2, 2010 | 01:03 PM
oznext's Avatar
oznext
Default 04 5.7 burning engine oil?
Hello buds, i have notice that in the last 2 oil changes i only drain 1 qt of oil, i changed it every 4 month becouse i dont use it that much, but recently i have been driving it daily and last week i check the level and it needed to add 2 qts, whats the deal is the engine gone bad already, i have been using 10w30 full synt, should i change oil type?
Old Dec 2, 2010 | 02:43 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
My 2007 with the MDS system requires 5W20, not sure if the 2004 requires this winter blend. Check your manual or the oil fill cap will tell you what to use,
FF
Old Dec 16, 2010 | 02:06 AM
fr0gster's Avatar
fr0gster
I have an '04 5.7L as well and it requires 5w-30. Like fascistfaction said check your oil fill cap to confirm. If not there it should be in your owners manual.
Old Dec 17, 2010 | 05:48 PM
HammerZ71's Avatar
HammerZ71
Pre-'05 Hemi engine requires 5w-30. But that ain't gonna make a difference as far as burning or losing oil. Have you checked for leaks? The Hemi is not really known to be an oil burner, so I'd be looking for a leak before digging into anything else. I'd for sure pull a plug and look for fouling though.
I run a premium synthetic and change at 5k intervals and even at that duration the oil at change time is right where it was on the stick when I put it in...
Old Dec 18, 2010 | 09:23 PM
oznext's Avatar
oznext
Thanks guys, no leaks thats for sure...
