2nd Gen Durango 2004 - 2009
Fastway E-2 Sway Control Hitch
Old Jan 2, 2011 | 09:41 PM
eeh42's Avatar
eeh42
Question Fastway E-2 Sway Control Hitch
Does anyone have experience using the Fastway E-2 10k Sway Control hitch towing a travel trailer with a D-Hemi?
The E-2 is suppose to be user friendly and allows backing up. Cost is about $400 + installation. Any thoughts or other recommendations?
Thanks,
Old Jan 10, 2011 | 01:05 AM
NoFearEyes's Avatar
NoFearEyes
Depends on what you are towing whether you really need the sway control system.
First make sure you have proper hitch weight on ball--should be around 400 lbs. Most sway problems are caused by improper hitch weight. Also make sure weight is even distributed on trailer and tires are at proper inflation.
I tow a 7000 boat with my 2005 Durango with the 5.7 and AWD. I just have factory tow package and proper height ball/drawbar. No problems and no sway issues with that configuration.
