2nd Gen Durango 2004 - 2009
04 ves headphones
Old Jan 9, 2011 | 01:49 PM
dawn728's Avatar
dawn728
Default 04 ves headphones
I bought my durango without factory headphones and now i am very interested in how to get aftermarket 900 mhz ones to work. When i push the headphone button on the remote it just shows up as ch on screen. Any suggestions would be great. I have read the ves manual and just cant understand and know nothing about cars except where to stick in the key and where to pump the gas! Thanks in advance
Old Jan 10, 2011 | 12:52 AM
NoFearEyes's Avatar
NoFearEyes
Found this on page 28 of the manual...
OPERATING INSTRUCTIONS — HEADPHONES
1. Power Button
2. Scan Button
3. Volume Control
4. LED
Power Button
Pressing the power button will turn the headphones
ON/OFF.
² The headphones will turn off automatically and the
red LED will illuminate for approximately 2 minutes
when the radio or rear audio system is turned off.
² The rear audio system must be turned ON before
sound can be heard from the headphones.
Volume Control
Rotate the volume control upward to increase the volume.
Scan Button
Pressing the scan button will automatically find the
audio signal that is transmitted from the VES when the
Rear Seat Audio System and the headphones are on. The
headphone LED will turn green when the channel is
received.
NOTE: When the 9GREEN LED9 is showing the headphones
are receiving the audio signal. When the RED
LED is showing the headphones are searching for the
audio signal. If the LED is off when power is on, the
batteries may need to be replaced.
Headphone Battery Service
² Using a key or similar flat object insert into the slot.
² Pry upward, towards the top of the headphones on the
release tab and remove the cover.
² Replace the batteries and reinstall the cover.
The replacement batteries for the headphones are three
AAA batteries.
General Information
This device complies with part 15 of the FCC Operation
is subject to the following two conditions:
5. This device may not cause harmful interference and
I haven't sat in the back seat and played with the VES yet--my kids got it to work thru the radio speakers because I hadn't found any headphones.
Finally got some RF headphones on ebay the other day.
I'll give them a try tomorrow and let you know if the "instructions" actually work as supplied.
Chrysler should be kicked in the a$$ for the "wordless" manuals and instructions they provide. Surely they didn't save enough printing cost by using this format to save the company from bankruptcy--they sure didn't help customer relations !
Old Aug 30, 2013 | 11:34 PM
onephat66's Avatar
onephat66
RCA brand WHP141. Can find them on Amazon and work great. Jim
