2nd Gen Durango 2004 - 2009
coolant leak under air filter box
Old Jan 31, 2011 | 03:10 PM
oznext's Avatar
oznext
Default coolant leak under air filter box
Hello, i have a coolant leak coming from an electronic valve seated right under the air filter box, do i have to replace the whole valve or just fix it wuht a new gasket, couldnt find the valve name either,,,thankyou for the help
Old Jan 31, 2011 | 09:02 PM
n8ech's Avatar
n8ech
OZ:
That would be your Aux Coolant Pump leaking which is common. It helps get the coolant mke the long trip to the rear heater core.
They go for ~$100-$130, and you can install it yourself pretty easily.
If your coolant is in need of a flush/refill, this would be a good time to do it all.
I have new hoses and a new T stat for my 04 to go in this Spring.
Don
Old Feb 2, 2011 | 09:49 PM
oznext's Avatar
oznext
Thanks Don, is there any way to fix it with a new O-ring or something?.. i have been spending a lot of money on my cars lately, just fixed a rear diferential on my jeep liberty.. :/
Old Feb 3, 2011 | 02:44 PM
n8ech's Avatar
n8ech
Oz:
Possibly you could removed it and take it apart to see where the leak is. Being pretty much plastic, I think the most common repair is replacement.
If you are short on the bucks for now, you might try temporarily installing a short piece of tubing in its place till you can fix the old one, or afford a new one.
Don
Old Feb 18, 2011 | 08:59 PM
oznext's Avatar
oznext
Thanks..
