Steering Problems
2002 Durango XL - 130K
Tires a year ago
Brakes 6 months ago
2 Months ago had power steering pump hoses all replaced.
Since then truck seems to pull to right a little bit.
Since then when I am driving straight or turning left, it feels like something is rubbing, or out of alignment.
The moment I put just a little "RIGHT" turn (even lane change) to the steering, it's as smooth as can be, until I"m back to center/straight again.
Suggestions? Where should I start?
Kevin
Connecticut.
Tires a year ago
Brakes 6 months ago
Kevin
Connecticut.
If it feels like the alignment is bad, and it acts like the alignment is bad, the alignment is indeed probably bad.
Likley culprits...
1) Get the alignment done... all 4 wheels
2) Sticky caliper
3) Failing bearing creating drag
If you haven't done #1 prior to posting the thread in the first place... shame shame
HTH,
IndyDurango
Likley culprits...
2) Sticky caliper
HTH,
IndyDurango
