Weird Electrical Problem
Hey guys, I am new here, I have a 2004 Durango with the 5.7L. I am having a little problem finding out a solution to a problem that has came up with my windows.
Last week I tried to roll down my windows after work and none of them worked, from any of the switches. However they all worked the day before. I am assuming it is a fuse, because I do not believe the switches are getting power (and I do not think all of the motors would go out at once)?
Does anyone know which fuse relates to the windows, and where it is? I haven't been able to have any success working on it this past week.
Thanks, here's some pictures of my Durango.
Under the hood, on the driver's side, there are 2 black boxes roughly 3" wide by 7" long. The covers just snap on. There are some fuses and relays there. I know it gives a description of what each one is on the bottom of the lid. I'll take a look at mine when I get home......but that might be a place to start. Sounds like it is probably a fuse or a relay.
I checked my Haynes manual last night. Per the wiring diagram, in the junction block (the fuse box in the panel by the drivers left leg) the window fuse is a 25 amp fuse located here. Check that. Also make sure you didn't accidentally push the window lockout button on the drivers door. Hope this helps.
did the fuse fix the problem? any updates on this? this just happened to me on my 04. went to the store, opened the window about a inch to vent the interior when i went in. went in, did my grocery shopping with the wife, came back out to the truck, loaded the groceries in the back, have all dome lights and everything else on the inside works fine, but when i went to open my window all the way, nothing. wont go up or down. none of them will. checked the window lock button, wasnt on, still nothing. checked my fuses, and they are all good. could it be something with the switch on the drivers door, perhaps a malfunctioning lock button? but then i would still be able to control all windows myself with the drivers side buttons. im stumped.... HELP!!
