2nd Gen Durango 2004 - 2009
04 durango a\c compressor oil
Old Jul 5, 2011 | 09:31 PM
heemi's Avatar
heemi
Default 04 durango a\c compressor oil
hello out there, put in a new a/c compressor but it came with out the oil in it. can any one tell me how much oil i should put in the compressor? I cant seem to find the info anywhere.
thanks..
Old Jul 7, 2011 | 09:31 AM
RangoBruce's Avatar
RangoBruce
Why are you replacing the compressor? when the system is opened it is recomended that you replace the RECEIVER DRYER also. if the compressor is damaged internally then you need to replace the EXPANSION VALVE also. hope this helps
_____________________________________________
Refrigerant Oil Capacities
Total System Fill - Front A/C Only 5.07 fl oz (150 ml) Total System Fill - Front and Rear A/C Only 7.40 fl oz (220 ml) Receiver/Drier 1.0 fl oz (30 ml) Front Evaporator 2.0 fl oz (60 ml) Rear Evaporator 1.0 fl oz (30 ml) Condenser 1.0 fl oz (30 ml) Compressor drain and measure the oil from the old compressor
