2nd Gen Durango 2004 - 2009
2005 dodge durango limited questions
Old Jul 6, 2011 | 01:15 AM
dss56's Avatar
dss56
Default 2005 dodge durango limited questions
How to remove 2005 dodge durango instrument panel is it easy or is there a video. I have a rattle seems on the driver upper side dash. I did get under the lower side and could not find anything loose.
When I hit a good bump it will rattle and to me seems its on the upper part.
Was hoping removing the cluster would allow me to see the upper part.
thanks
Old Jul 7, 2011 | 09:10 AM
RangoBruce's Avatar
RangoBruce
here are the steps, hope this helps. would not recomend doing this unless you have some exprience
WARNING:
  • TO AVOID PERSONAL INJURY OR DEATH, ON VEHICLES EQUIPPED WITH AIRBAGS, DISABLE THE SUPPLEMENTAL RESTRAINT SYSTEM BEFORE ATTEMPTING ANY STEERING WHEEL, STEERING COLUMN, AIRBAG, OCCUPANT CLASSIFICATION SYSTEM, SEAT BELT TENSIONER, IMPACT SENSOR, OR INSTRUMENT PANEL COMPONENT DIAGNOSIS OR SERVICE.DISCONNECT AND ISOLATE THE BATTERY NEGATIVE (GROUND) CABLE, THEN WAIT TWO MINUTES FOR THE SYSTEM CAPACITOR TO DISCHARGE BEFORE PERFORMING FURTHER DIAGNOSIS OR SERVICE. THIS IS THE ONLY SURE WAY TO DISABLE THE SUPPLEMENTAL RESTRAINT SYSTEM. FAILURE TO TAKE THE PROPER PRECAUTIONS COULD RESULT IN ACCIDENTAL AIRBAG DEPLOYMENT.
  • TO AVOID PERSONAL INJURY OR DEATH, NEVER STRIKE OR DROP THE OCCUPANT RESTRAINT CONTROLLER, AS IT CAN DAMAGE THE IMPACT SENSOR OR AFFECT ITS CALIBRATION. THE OCCUPANT RESTRAINT CONTROLLER CONTAINS THE IMPACT SENSOR, WHICH ENABLES THE SYSTEM TO DEPLOY THE SUPPLEMENTAL RESTRAINTS. IF AN AIRBAG CONTROL MODULE IS ACCIDENTALLY DROPPED DURING SERVICE, THE MODULE MUST BE SCRAPPED AND REPLACED WITH A NEW UNIT. FAILURE TO OBSERVE THIS WARNING COULD RESULT IN ACCIDENTAL, INCOMPLETE, OR IMPROPER SUPPLEMENTAL RESTRAINT DEPLOYMENT.
CAUTION : On vehicles equipped with the Occupant Classification System (OCS), never replace both the Occupant Restraint Controller (ORC) and the Occupant Classification Module (OCM) at the same time. If both require replacement, replace one. Then perform the supplemental restraint verification test before replacing the other. Both the ORC and the OCM store OCS calibration data, which they transfer to one another when one of them is replaced. If both are replaced at the same time, an irreversible fault will be set in both modules.
REMOVAL
  1. Before proceeding with the following repair procedure, review all warnings and cautions.
  2. Disconnect and isolate battery negative cable.
  3. Using a trim stick C-4755 or equivalent, remove the left door sill trim cover.
  4. Remove the screw and remove the left cowl trim cover.
  5. Remove the left instrument panel end cap.
  6. Remove the two screws (1) and remove the steering column opening cover (2).
  1. Remove the screws (5) and position aside the hood release handle (2).
  1. Remove the four screws (2) and remove the steering column opening reinforcement (1).
  1. Remove the steering column tilt lever.
  2. Remove the upper (1) and lower (3) column shrouds.
  1. Disconnect the wiring harness connectors (1) to the column.
  2. Remove the shift cable from the column shift lever actuator.
  3. Release the shift cable from the column bracket and remove it from the bracket.
  4. Remove the SKIM module in order to disconnect the electrical connector.
  1. Remove the upper steering shaft coupler bolt (2) and slide the shaft (3) down.
  1. Remove the brake light switch (5) and discard.
  1. Remove the four steering column mounting nuts (3).
  2. Lower the column from the mounting studs (1).
  3. Remove the steering column assembly (2) from the vehicle.
Remove the pedal support bracket bolts.
  1. Disengage the release rod (1) from the arm on the pedal assembly.
  1. Disconnect the electrical connectors (1, 2 and 3) from the fuse block.
  2. Remove the bolt and remove the ground wire (4).
  3. Open the trim covers in the drivers side a-pillar grab handle and remove the bolts.
  4. Remove the a-pillar trim panel.
  5. Remove the floor console.
  1. Disconnect the two body wire harness connectors
  1. from the Occupant Restraint Controller (ORC)
  2. connector receptacles located on the forward facing side of the module. To disconnect the wire harness connectors from the ORC, depress the release tab and lift the lever arm on each connector.
  1. Position the carpet aside and remove the center harness screws (1). Pull instrument panel wiring harness (2) from under the carpet.
  1. Remove the center support bolts.
  2. Remove the drivers seat.
  3. Remove the drivers side floor duct.
  1. Remove the drivers side support bolts.
  1. Remove the right instrument panel end cap.
  2. Remove the passenger side support bolts.
Note : Drivers side shown, passenger side similar.
  1. Using a trim stick C-4755 or equivalent, remove the right door sill trim cover.
  2. Remove the screw and remove the right cowl trim cover.
  3. Remove the bolts and remove the amplifier.
  4. Disconnect the amplifier and antenna electrical connectors.
  1. Remove the harness bolt (1) and the ground wire(3) bolt (2).
  2. Remove the passenger side rear floor duct.
  1. Open the trim covers in the passenger side a-pillar grab handle and remove the bolts.
  2. Remove the a-pillar trim panel.
  3. Using a trim stick C-4755 or equivalent, remove the instrument panel defroster grille.
  4. Disconnect the sensor electrical connector (2).
  1. Remove the four fenceline bolts (2).
  2. Lift the instrument panel assembly (3) off the side support pins (1) and remove assembly through the drivers door.
Old Jul 7, 2011 | 09:29 AM
dss56's Avatar
dss56
Thanks for the pics.
Seems like a lot to remove. I just wanted to get behind the speedometer / tach panel to see if I can find anything.
What happened to just a few screws for removal.
My 2004 Dodge Quad cab is just a few screws and it pulls forward and just some plugs and its removed.
Might have to hire Mini Me to crawl up there and see what is going on
Thanks
Old Jul 7, 2011 | 09:38 AM
RangoBruce's Avatar
RangoBruce
to remove just the speedo/tach is only a few screws and should be similar to your Quad cab. I thaught you wanted to remove the complete Dash.
Old Jul 7, 2011 | 10:33 AM
dss56's Avatar
dss56
Just need the gauge panel removed gas temp tach batt spedo
Old Jul 10, 2011 | 01:45 PM
dss56's Avatar
dss56
What are these pictures for seems not ot the instrument panel with the gas guage batt/temp right behind the steering wheel just curious
WARNING:
REMOVAL
